Thought I'd better start on making that rotisserie today as the body of the car has been in the way most of the week
..............old rusty cars..............
Felt that the best and quickest way would be to use a couple of engine stands and seeing as I already had one I just bought a 2nd used one locally.
Started out making the mounts that bolt on the bumper mounts in the body, mainly tried to use scrap steel that we already had at work so it was a case of whatever works.
Figuring out where the center of gravity was on the body became a bit of a guessing game so after deciding how high to make the stands I cut up one of the engine stands and lengthened it by about 200mm and also widened it between the wheels to make it more stable.
That worked out pretty well and with the body hanging level in the gantry crane I could then measure up the back of the car and make the stand for that end.
With the 2nd stand done I dropped it down on the ground but it became evident pretty quickly I'd need to tie the stands together to stop them splaying out.
Some simple furniture tube bolted between the stands sorted that problem out pretty quick.
The great thing is that when this is done I can then use this stand for the Convertible and all I need to change is where it bolts to the body
Its certainly not going to win any awards but I didn't feel like spending all day making this thing so rough and ready it is!!
Balance is perfect, spins over very nice and at no time does it want to suddenly drop away from you so that's pretty cool.
Will be miles easier to work on the lower half of the body this way.
